Hey guys, as i finally got some miles on the turbos i decided to go ahead and install the electronic boost controller that i had bought. It was obvious that there were boost leaks when i attempted to set it. So i took care of the boost leaks and turned up the boost to 11.5 and now the car will miss occasionally in cylinder 6(sounds like a subi). I ohmed out the injector, changed the coil pack and rechecked the sparkplug gap which has 500 miles on it. Wire harness is new. Now im considering a fuel problem but i don't believe it would effect just one cylinder. I also have to check for codes which i will be doing today, just thought i would try to get some input. Also the car running on the waste gates never did this.
Thanks Tomas
intermittent miss on 6 - tomas132906:02:28 06/14/11
